Sam no long accepting sub hourly load files when hourly weather files used.
- mark.norman
30 Jul 2015 00:09 #3586
by mark.norman
Sam no long accepting sub hourly load files when hourly weather files used. was created by mark.norman
Version - 2015.06.30 (update 1)
System - MS Windows 7 SP1
Module - PhotoVoltaic (detailed), commercial
Hi
Why has SAM stopped accepting sub-hourly load files as previous versions did?
Error message:
exec fail(pvsamv1): electric load profile must have same number of values as weather file, or 8760
Simulation pvsamv1 failed.
Thank you for creating and maintaining SAM
Regards
Mark
Hi
Error message:
Regards
Mark
05 Aug 2015 11:58 #3587
Replied by Paul Gilman on topic Sam no long accepting sub hourly load files when hourly weather files used.
Dear Mark,
There are a couple of reasons we made this change. The main reason is that with the new battery model (for photovoltaic systems), it does not make sense to run simulations with hourly weather data and subhourly load data because the battery needs to respond to both power available from the array and required by the battery in the same time step.
Also, in older versions of SAM, when you used hourly weather data with subhourly load data, SAM used the subhourly load data to determine the peak load in a month, but the hourly solar data to determine the photovoltaic system's output in each time step. That did not represent how system might reduce the peak load very well.
So, in the current version, we think you should use the same time step for the weather data and load data. If you want to use hourly weather data with subhourly load data, you could modify the weather file, perhaps by using linear interpolation to estimate subhourly values from the hourly values.
- mark.norman
06 Aug 2015 08:39 #3588
by mark.norman
Replied by mark.norman on topic Sam no long accepting sub hourly load files when hourly weather files used.
Dear Paul
Thanks for the clarification
Regards
Mark
Regards
Mark
- clarknd
01 Oct 2015 11:04 #3589
by clarknd
Replied by clarknd on topic Sam no long accepting sub hourly load files when hourly weather files used.
What is the maximum time step allowed for sub-hourly simulations?
02 Oct 2015 11:47 #3590
SAM's solar performance models will run with a weather file with time steps ranging from 1 minute to 60 minutes.
