Unable to View options under " Tabular Data Browser"
- Vijaykrishna
12 Mar 2012 10:18 #353
by Vijaykrishna
Unable to View options under " Tabular Data Browser" was created by Vijaykrishna
Under the Output page under "tabular data browser" i could always choose what quantities i wanted to view. However after i upgraded my computer ( to a dell precision T1600 with a Xenon processor) with the latest version of Sam(sam-win32-2011-12-2) installed, i am unable to view choices under the "tabular data browser" tab, Please see image attached . I tried installing legacy versions of Sam to see if issue was specific to the latest release, but it did not make any difference. Any suggestions?
VIjay
VIjay
12 Mar 2012 12:27 #354
Replied by Paul Gilman on topic Unable to View options under " Tabular Data Browser"
I'm checking in with the programmers to see what the problem might be. In the meantime, please try pressing F7 and F3 for each case to clear results and the cache and then running simulations again. Does that solve the problem?
(Those commands are also available from the Case and File menues, respectively.)
12 Mar 2012 13:23 #355
Hi again -- One possibility is that the number of cases in your file is using up graphical resources. Please try creating a new file with a single case and let me know whether the data tables display correctly.
If the data tables display correctly in the file with one case, limiting the number of cases in your files to two or three may avoid the issue. To continue working with your current file with five cases, you could make two copies of the file, and delete two or three of the cases in each.
This issue may be more of a problem in SAM 2011.12.2 than in older versions because the new version's integrated time series data viewer makes more demands on your computer's graphical resources than older versions. Different computers with different graphical resources will be more or less affected by this issue.
- Vijaykrishna
12 Mar 2012 16:09 #356
by Vijaykrishna
Replied by Vijaykrishna on topic Unable to View options under " Tabular Data Browser"
Sir Paul,
Thanks again for all the prompt replies. I tried F3/F7 key to Clear cache and tried deleting all the cases( to just one, as you had mentioned) but still no luck. I am running a xenon 3.1 GHz with 8 Gm ram and a Nvedia Quadro 600 Graphics card. I use this machine for modelling to, so my graphic resource should not be an issue. I have attached an updated screen shot( with all but one case deleted).
Please let me know if you would need any thing else from my side.
Thanks again
Vijay
Thanks again
Vijay
12 Mar 2012 17:27 #357
Thank you Vijay for helping us troubleshoot this issue.
Do you have the same problem when you start from scratch? Please try starting SAM and creating a new file and let me know whether you see the data tables after running simulations.
- Vijaykrishna
13 Mar 2012 11:53 #358
by Vijaykrishna
Sir Paul-
Created a new case from scratch, but it still did not solve the issue.
I am working of my Personal laptop now!.
Thanks again for your prompt replies! Please let me know if i could be of any more assistance.
Vijay
Vijay
