Molten salt model, TES level
- rid7043
15 Jun 2015 03:26 #3425
by rid7043
Molten salt model, TES level was created by rid7043
I have a molten salt tower model and when I export the result and plot them, there are values over the maximum allowed level (I consider as allowed value the one in the System cost-storage(MWht)).
15 Jun 2015 11:11 #3426
Replied by Paul Gilman on topic Molten salt model, TES level
Can you be more specific about what you are seeing? For what hours to you see the unexpected values? How do you define "maximum allowed level?"
- rid7043
16 Jun 2015 01:25 #3427
by rid7043
Replied by rid7043 on topic Molten salt model, TES level
The maximum allowed value I consider is the one in system cost/storage (that value according to the help is used to calculate the cost per thermal megawatt-hour, but I suppose that it should be the maximum value too.
To obtain the current level in the storage[MWht], I add previous thermal energy in the storage and the TES thermal energy into storage minus the TES thermal losses from tank. (This procedure gives sometimes negative values that are changed by zero)
16 Jun 2015 11:09 #3428
The system's nameplate capacity is a nominal value that is used for cost calculations. The model does not use that value as a maximum limit on the system's output. The system's simulated output may exceed the nominal value under some conditions.
- rid7043
17 Jun 2015 03:17 #3429
by rid7043
Which are the conditions to determine the TES level? It is influence by the ambient temperature?
Many thanks
Many thanks
19 Jun 2015 09:28 #3430
For a description of the thermal storage model, please see Chapter four of Wagner (2011) Technical Manual for the SAM Physical Trough Model (
PDF 3.7 MB
). SAM uses the same model for the TES in the physical trough model and molten salt power tower model.
