PVWATTS Implementation of Feuntes Thermal Model
- Jody Dillon
29 May 2015 07:34 #3394
by Jody Dillon
PVWATTS Implementation of Feuntes Thermal Model was created by Jody Dillon
Hi! I am a researcher at the Electricity Research Centre at University College Dublin, Ireland.
First off, many thanks for making this tool available and for publishing the details.
I have a question about the implementation of the Fuentes thermal model in PVWATTS. I have implemented this myself in GAMS, (by basically translating the Fortran 77 code found in the Fuentes reference) and the results I get using the same climate data etc. are very close to PVWATTS, but slightly different. The total DC energy over the year is within 0.7%.
Since I can exactly replicate the results from the module and inverter models, I would like to find the source of the difference in the thermal model. The only correlation I can see is that the error I observe is larger when the wind speed is low.
In the PVWATTS implementation of the Fuentes thermal model, do you use the same module characteristics as in the referenced paper? I.e.:
Reflectivity: 0.10
Efficiency: 0.08
(Emissivity: 0.84 – derived from the two parameters above)
Thermal mass/capacitance: 11000 J/m^2 degC
Did you guys make any adaptations to the Fuentes model?
I would be grateful for any assistance you could provide.
Reflectivity: 0.10
Efficiency: 0.08
15 Jun 2015 12:18 #3395
Replied by Paul Gilman on topic PVWATTS Implementation of Feuntes Thermal Model
The PVWatts V5 cell temperature model assumes an emissivity constant of
. The model uses that value in equations that calculate a ground temperature ratio and ratio of total convection to top side convection.
It assumes an initial thermal capacitance of
, which it uses to calculate the module's thermal capacitance:
That's what I can glean from the source code -- it does not mention specific adaptations or modifications to the original model.
emmis = 0.84
capo = 11,000
/* Adjust the capacitance of the module based on the inoct */<br />
cap=capo;<br />
if( inoct > 321.15)<br />
cap=cap*(1.0+(inoct-321.15)/12.0);
