Copy to Clipboard - Function - Under Cash Flow Section (OS X)
- schmidly
15 May 2015 15:47 #3341
by schmidly
Copy to Clipboard - Function - Under Cash Flow Section (OS X) was created by schmidly
Paul, I just wanted to bring to your attention that this function does not appear to be working on my OS X system. I'm running the SAM 2015.1.30 version. Can you verify on your Macbook? Thanks in advance, Brian
18 May 2015 10:27 #3342
Replied by Paul Gilman on topic Copy to Clipboard - Function - Under Cash Flow Section (OS X)
Dear Brian,
As it turns out, that feature doesn't work properly in Windows either. We've fixed it for the next version, which we hope to release early this summer.
In the mean time, you can use Save as CSV to export the data.
- schmidly
18 May 2015 15:52 #3343
by schmidly
Replied by schmidly on topic Copy to Clipboard - Function - Under Cash Flow Section (OS X)
Paul, that's what I've been doing, but I knew you were planning to release an update this summer, and so I just wanted to bring this issue to your attention. Thanks for looking into it and sending me a work-around solution. Regards, Brian S.
