SAM inverter specs different from CEC database
- bobsil
29 Apr 2015 22:23 #3295
by bobsil
SAM inverter specs different from CEC database was created by bobsil
The CEC specifications for the SMA inverter SB6000TL-US-22 (240V) dated May 01, 2014 can be found at
www.gosolarcalifornia.org/equipment/inverter_tests/summaries/SMA%20SB6000TL-US-22%20%28240V%29.pdf .
That document, as well as the SMA datasheet, specify Vmin = 210V.
SAM, on the other hand, specifies Vmin = 345V.
Another discrepancy that caught my eye is for the SB7700TL-US-22 (240) for Vnom:
SAM: 407.8V, CEC: 400V
Are these values in SAM incorrect?
01 May 2015 11:00 #3296
Replied by Paul Gilman on topic SAM inverter specs different from CEC database
We receive data for SAM's CEC inverter library from the CEC. The discrepancies you found may be errors in the database. We will investigate. Thank you for bringing them to our attention.
