Flux maps and detailed output in SAM 30/1/2015
16 Mar 2016 13:57 #3279
Replied by Paul Gilman on topic Flux maps and detailed output in SAM 30/1/2015
The molten salt power tower model in SAM 2016.3.14 and later versions report the following new output variables. They appear on the Data tab of the Results page under "Matrix Data", and are also available as variables via LK script:
Flux map intensities (flux_maps_out)
Solar field optical efficiencies (eta_map_out)
Heliostat position tables (helio_positions)
- Monteleone91
15 Mar 2017 10:11 #3280
by Monteleone91
Replied by Monteleone91 on topic Flux maps and detailed output in SAM 30/1/2015
The field efficiency matrix is available as output variable of programme SolarPILOT?
20 Mar 2017 20:30 #3281
In SAM, the SolarPILOT field efficiency matrix is available on the Data tables tab as described above.
In the standalone version of SolarPILOT, you can also find that matrix and other data.
- Monteleone91
21 Mar 2017 04:22 #3282
by Monteleone91
If I don't use SAM but only SolarPILOT, the field efficiency matrix is available?
24 Mar 2017 14:07 #3283
Yes. The field optical efficiency table is an output of SolarPILOT.
