Need help to include files into lirary for a MAC based system
- Mithras CSP
23 Feb 2012 06:27 #322
by Mithras CSP
Need help to include files into lirary for a MAC based system was created by Mithras CSP
Hello Paul !
thanks for your help regarding the library entries and your hint regarding the IAM !
For a colleague of mine who is working on a MAC based system, we are facing now a problem that we cannot enter new files in the library and climate-date folder prior to import them to SAM.
Do you have an idea what we are doing wrong ??
Are the folders in the MAC version of SAM write protected or simmilar ?
Thanks again !
Kind Regards,
Marc
Thanks again !
Kind Regards,
Marc
27 Feb 2012 10:38 #323
Replied by Paul Gilman on topic Need help to include files into lirary for a MAC based system
On Mac OS, SAM stores its application files in the following folder:
.../SAM.app/Contents/MacOS/exelib
For example, the weather data files are in the following folder
SAM.app/Contents/MacOS/exelib/climate_files
When you use the TMY3 Creator, the first step is to open a "base TMY3 file," but when you try to do that on a Mac, SAM looks in a different folder that causes an error. To work around this problem, copy the TMY3 file(s) you want to use as the base file from the climate_files folder to a new folder that you can easily find. Then on the Climate page, click Add/Remove, and add the folder to the list of folders SAM searches for weather files. Now when you use the TMY3 Creator, load the base TMY3 file from that folder instead of the default folder that causes the error.
Similarly, the libraries are stored in .samlib files in the following folder
SAM.app/Contents/MacOS/exelib/libraries
To modify a library, first copy its .samlib file to a folder you can find, and then use the Library Editor to navigate to that copy of the file.
I realize those instructions may be confusing, so please let me know if you need clarification.
