Importing input files from json to PySAM for Pvwattsv8
- Jaco
12 Mar 2024 22:58 - 13 Mar 2024 16:12 #12978
by Jaco
Importing input files from json to PySAM for Pvwattsv8 was created by Jaco
There are two parts to my question.
The first is that I am unable to achieve comparable results when building a Pvwattsv8 No financial model in pySAM compared to those obtained in the SAM application. Specifically comparing achieved capacity factors. The pySAM model consistently produces lower capacity factors compared to the SAM application.
A link to those files can be found here .
The second part is in regard to issues when importing JSON inputs.
This was done following the example code from the documentation below, however I encounter the error:
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xb0 in position 41: invalid start byte.
The json file was downloaded from the code generator, and the SAM application and pySAM versions are 2023.12.17. and v5.0
Could you please advise on what might be causing this problem?
Thanks in advance for your help.
Jaco
import json
import PySAM.Pvwattsv8 as pv # import the PVWatts module from PySAM
# create a new instance of the Pvwattsv8 module
pv_model = pv.new()
# get the inputs from the JSON file
with open( 'untitled1_pvwattsv8.json', 'r') as f:
pv_inputs = json.load( f )
# iterate through the input key-value pairs and set the module inputs
for k, v in pv_inputs.items():
if k != 'number_inputs':
pv_model.value(k, v)
# run the module
pv_model.execute()
# print results
print('Annual AC output for {capacity:,.2f} kW system is {output:,.0f} kWh.\n'.format(capacity = pv_model.value('system_capacity'), output = pv_model.Outputs.ac_annual) )
Jaco
Last edit: 13 Mar 2024 16:12 by Paul Gilman. Reason: Please attach images as files and then insert them into your message
13 Mar 2024 16:17 #12982
Replied by Paul Gilman on topic Importing input files from json to PySAM for Pvwattsv8
Hi Jaco,
Please attach the .json and .sam files for the first part of your question, and the .json file for the second part if you would like me to help troubleshoot. I could not access the files the Google Drive link you provided.
You should be able to attach each file individually, or you can zip them into an archive and attach the .zip file.
- Jaco
13 Mar 2024 18:34 #12983
by Jaco
Replied by Jaco on topic Importing input files from json to PySAM for Pvwattsv8
Please find attached.
Kind Regards,
Jaco
Kind Regards,
Jaco
15 Mar 2024 10:40 - 15 Mar 2024 10:42 #12986
Hi Jaco,
Thank you for attaching the files.
For the first question, in your SAM file, the array type is set to "1-axis tracking." In the Python script, array_type = 1, which is the fixed roof mount option. That explains the difference in capacity factor between the two.
For the second question, we are investigating this UnicodeDecodeError. I think you can work around the problem by deleting the five "adjust" variables from the JSON file:
"adjust_constant" : 0,
"adjust_en_timeindex" : 0,
"adjust_en_periods" : 0,
"adjust_timeindex" : [ 0 ],
"adjust_periods" : [ [ 0, 0, 0 ] ]
Last edit: 15 Mar 2024 10:42 by Paul Gilman.
21 Mar 2024 09:35 - 21 Mar 2024 09:36 #13014
Hi Jaco,
It turns out that the SSC variable names that start with 'adjust_' are named without the "adjust_" in PySAM. For example, for Pvwattsv8, 'adjust_constant' in SSC (the name used for defaults and JSON generated by SAM) is 'constant' in PySAM.
We will fix this in an update to PySAM: github.com/NREL/pysam/issues/164 .
For now the workaround is to rename the "adjust" variables when you read them from defaults or a SAM-generated JSON file. For example:
Sorry about that! Thank you for helping us find this problem.
if 'adjust' in k:
k = k.split('adjust_')[1]
Last edit: 21 Mar 2024 09:36 by Paul Gilman.
- Joseph Dvorak
11 Jun 2024 08:07 #13247
by Joseph Dvorak
Replied by Joseph Dvorak on topic Importing input files from json to PySAM for Pvwattsv8
I ran into the same issue.
However, I had to adjust the workaround as the provided code triggered on "cec_adjust" in my json file. I added the underscore after adjust to prevent it from triggering on that entry.
Here is the code I had to use:
I'm just providing this in case someone else had a similar issue.
if 'adjust_' in k:
