Tilt and Azimuth angles
- sidom
20 May 2014 01:58 #2346
by sidom
Tilt and Azimuth angles was created by sidom
Working with CSP model, is it possible to define a typical N-S solar field orientation with a ground slope of 1º to the East (which means that East is 1º higher than West)?
Looking to the user manual it seems to be Azimuth = 0º to N-S orientation but I am not sure about how to define the slope to the East. Tilt equal to 1º is that the south of the solar field is 1º up than the north?
I am working with a Project in the north hemisphere.
Thanks in advance.
Thanks in advance.
20 May 2014 09:50 #2347
Replied by Paul Gilman on topic Tilt and Azimuth angles
SAM's CSP models do not have an input for ground slope. They all assume that the collectors are installed on level, horizontal ground.
- Darko Fius
20 May 2014 13:44 #2348
by Darko Fius
Replied by Darko Fius on topic Tilt and Azimuth angles
Level your units, there is no need as such to account for slope.
Best regards
Best regards
- sidom
21 May 2014 01:42 #2349
by sidom
Replied by sidom on topic Tilt and Azimuth angles
Thanks for your response.
And Tilt means the elevation of one end of the collectors with respect to the other end, and in the direction of the axis?
21 May 2014 09:43 #2350
Yes, that is a fair description of the tilt angle for collectors in the solar field of a CSP system in SAM.
- sidom
21 May 2014 10:42 #2351
by sidom
So, I only could simulate ground slopes in the direction of this axis. Is this supposition correct?
Thanks again
Thanks again
