Is there a clear explanation of Packing Factor (an option in the solar Array page)?
  • Anonymous Jerk
  • Topic Author
26 Jan 2012 01:26 #233 by Anonymous Jerk
Hi all,
In SAM's PV simulation, the Array page has a section on Land Area, which is largely determined by a packing factor. The default on SAM is 2.5, but this explanation www.nlr.gov/docs/fy11osti/49417.pdf (p6) seems counter to the default.
How does SAM consider the packing factor value? And how should we calculate it for a simple, fixed-axis roof mount?
Many thanks!
  • Paul Gilman
01 Feb 2012 12:23 #234 by Paul Gilman
For the PV component-based models, SAM uses the packing factor on the Array page to calculate the number of acres of land required for the project. When you specify a non-zero land cost in $/acres on the System Costs page, SAM uses the number of acres to calculate the land-related costs, which contribute to the total indirect cost. For a rooftop system, an appropriate value for land area would be zero.
  • Anonymous Jerk
  • Topic Author
03 Feb 2012 20:35 #235 by Anonymous Jerk
Thank you for the reply. Maybe I should have explained my situation:
I'd like to see how much land area is required for arrays of differing PV modules in differing locations (rooftop, flat land, slopes). I know that Packing Factor affects this, so I'm hoping to find a way to accurately calculate packing factor. Let me try these questions:
What does a PF of 2.5 mean?
Under what conditions should PF be changed?
How should we calculate PF for different scenarios?
Many thanks!
  • Paul Gilman
15 Feb 2012 16:30 #236 by Paul Gilman
SAM calculates the total land area by multiplying the packing factor by the total module area and converting it to acres. The calculation is explained in the Help topic for the Array page.
For example, the default Photovoltaics, Commercial case has a total module area of 1477.87 m2 and a packing factor of 2.5 (from the Array page). SAM shows the land area in acres as a calculated value on the Array page and the PV System Costs page: Total land area = 1477.87 m2 x 2.5 / 4,047 m2/acre = 0.91 acres.
The packing factor only affects the results of your simulation if you specify either land or land preparation cost in $/acres on the PV System Costs page. In the default case, both of these variables are zero, so the packing factor does not affect the results.
The packing factor is designed to be used for large, ground-mounted systems where land area-related costs are a factor.
If land-related costs are important for your analysis, you may want to research the relationship between total module area and land area for different installed systems to get a sense of what value to use for your analysis.
Unfortunately, the term "packing factor" is also sometimes used to describe the density of solar cells in a PV module, which is a different use of the term than in SAM.
  • Kloba
27 Feb 2012 14:43 #237 by Kloba
In answer to the original question:
Yes, there are different definitions of packing factor, and the one used in SAM is different from the one used in the document referenced above ( www.nlr.gov/docs/fy11osti/49417.pdf ) and both are different from how I've seen it stated elsewhere, such as this DOE glossary: www1.eere.energy.gov/solar/solar_glossary.html#P
In any case, the geometry depicted in the diagram you referenced is still useful in determining an appropriate packing factor.
Assuming the SAM definition of packing:
With flat (tilt = 0) modules, using a unity (1) packing factor gives only the area occupied by modules, so you will want to increase it to accommodate service access, inverter equipment, etc.
With tilted modules, the spacing chosen will determine when a module will become shaded by the adjoining module. This depends on latitude and tilt.
To get packing factor from row-to-row spacing:
p = (d / l) cos t, where
p = packing
d = row-to-row spacing
l = module width
t = tilt from horizontal.
Again, this only accounts for modules (and the spaces between rows), so increase somewhat for service access, inverter equipment, etc.
  • Fred Bloom
21 Jul 2014 17:55 #238 by Fred Bloom
Had the same question and can't believe how the scientists can't seem to comprehend the practical application. We're looking at a 50 acre parcel or 500,000 sq. ft. rooftop and we need to know how many kW's or mW's to quote for the bid. Right? For example, Here is what I was taught to determine a fixed tilt:
300 watt Sun Power panel is 1.63 sq. M
300 Watts/1.63m2= 184 Watts per m2
184 = 1m2 therefore
1mW = 5434 m2 of panel surface per mW
If installed at 15% tilt and leave 33% space between rows to prevent shading:
Then add 48 % to surface area
also
Then add 7 % for aisles, etc.
then : 5434 X 155% = 8424 m2 per mW of area needed
1 acre=4046 m2
therefore: .48 mW DC per acre (fixed tilt at 15%)
What is the equation to determine maximum panels without shading for a single axis tracker?, please advise.
Powered by Kunena Forum
