Battery Replacement Cost
- inreco
09 Nov 2025 11:29 #14366
by inreco
Battery Replacement Cost was created by inreco
In the spreadsheet the Battery Replacement line item is zero. Where in SAM do I change that to actual dollar amounts.
12 Nov 2025 09:31 - 14 Nov 2025 17:06 #14367
Replied by Paul Gilman on topic Battery Replacement Cost
For configurations with battery storage, you can set the battery replacement cost in $/kWhdc of battery capacity on the Operating Costs input page.
Last edit: 14 Nov 2025 17:06 by Paul Gilman.
- inreco
12 Nov 2025 12:47 #14371
by inreco
Replied by inreco on topic Battery Replacement Cost
so after doing that it puts in it's cost which is 1/4 the actual cost. Can I enter the actual cost anywhere?
14 Nov 2025 17:17 #14372
The battery replacement cost on the Operating Costs input page is in $/kWhdc of battery storage capacity, which is shown at the top of the "Battery" column on that page.
For example, for this residential battery, the battery replacement cost would be 434 $/kWhdc * 12.5 kWh dc = $54,300 in Year 1 dollars. SAM applies the inflation rate from the Financial Parameters page to calculate the cost in the replacement year.
- inreco
17 Nov 2025 10:22 #14375
by inreco
And where do I input the necessary Inverters for the batteries?
17 Nov 2025 15:50 #14377
For a DC-connected battery coupled to a PV system, the inverter on the Inverter page converts DC power from both the battery and PV array to AC power.
For an AC-coupled battery, the DC to AC conversion efficiency input on the Battery Cell and System page (under "Power Converters") accounts for conversion losses in the inverter.
