negative PAO front-side shading losses...
- Mirko Dudas
01 Dec 2023 03:54 #12709
by Mirko Dudas
negative PAO front-side shading losses... was created by Mirko Dudas
when simulating vertical pv systems I get
(1) negative POA front-side shading losses
(2) negative system power generated during night hours
(3) when sorting the system power generated numbers descending, the highest ten or twelve values are identical. Looks like they are cut off.
Any idea what I'm doing wrong?
Mirko
Mirko
01 Dec 2023 15:24 #12713
Replied by Paul Gilman on topic negative PAO front-side shading losses...
Hi Mirko,
I was not able to replicate the negative POA front-side shading loss (%) value. Please attach a .sam file along with your .csv weather file if you would like me to troubleshoot.
The negative "system power generated" values at night are probably for inverter nighttime consumption. That is caused by the Power use at night input on the Inverter page.
SAM does limit the system output to the inverter's AC capacity rating, so those identical values of system power generated are probably due to inverter power limiting.
- Mirko Dudas
02 Dec 2023 02:55 #12714
by Mirko Dudas
Replied by Mirko Dudas on topic negative PAO front-side shading losses...
thank you for your fast response. Enclosed you'll find the .sam file as well as the weather file that I downloaded from PVGIS. Do the same values show up on your screen?
Greetings from Munich
Mirko
Mirko
04 Dec 2023 17:04 #12722
Hi Mirko,
Thank you for attaching the files.
I think the negative POA losses are caused by the combination of the "standard non-linear" self shading option and vertical (tilt = 90 degrees) array. I would recommend using the "thin film (linear)" option to estimate the self shading loss. The "standard" option is an empirical model based on measurements from systems with non-vertical arrays.
- Mirko Dudas
04 Dec 2023 20:59 #12723
by Mirko Dudas
thanks for troubleshooting. The "thin film" option works better, although the calculations might overestimate the actual energy yield, especially for systems with high gcr. Paul, do you have any idea how to roughly estimate the differences in yield (between thin film and non-linear self-shading) depending on gcr for vertical panels? A rule of thumb or so?
Anyway, thanks for your assistance.
Mirko
Mirko
05 Dec 2023 16:48 #12730
Hi Mirko,
I don't have a suggestion of a rule of thumb for this adjustment. You might try comparing results for the linear and non-linear self shading options for a non-vertical array in SAM to get a sense of the difference in yield.
