proxy settings in SAM?
- softarts
23 Jan 2013 18:43 #1206
by softarts
proxy settings in SAM? was created by softarts
we use proxy to access external HTTP in our firm. Does SAM allow us to config proxy ? We had a quick look at the menu but do not see.
24 Jan 2013 12:24 #1207
Replied by Paul Gilman on topic proxy settings in SAM?
SAM does not have configuration settings for the web services it connects to, such as for downloading weather data or incentives data.
- softarts
24 Jan 2013 19:20 #1208
by softarts
Replied by softarts on topic proxy settings in SAM?
thanks for replying.
so we need to open firewall to access your service, would you please advise the ip/port on your side that we need to open ?
Tina
Tina
30 Jan 2013 09:48 #1209
Hi Tina,
I am working with the web team to answer your question. It is not clear to us exactly what information you need because SAM accesses the web services it uses via HTTP.
- clarknd
22 Apr 2014 07:48 #1210
by clarknd
Replied by clarknd on topic proxy settings in SAM?
This is Nathan Clark. I used to work with Steve and Aron on the SAM utility rate database implementation. Now I work on Black & Veatch and we are having the same problem. Has this problem been figured out yet?
Thanks!
Thanks!
22 Apr 2014 09:55 #1211
Hi Nathan,
We have not identified the cause of the problem yet, partly because it has been difficult for us to find out what specific information IT departments need to resolve the proxy issue. Can you help us with that? What information can we provide that will allow SAM to access the web services from behind your firewall?
Also, are you only having trouble accessing the web services (utility rate database, weather file databases, etc.) or are you also having trouble downloading the SAM installation file from the website?
Paul
Paul
