LCOE changes with different PPA values, even without debt, taxes, etc
- Colin Schimmelfing
13 Jan 2022 18:48 #10508
by Colin Schimmelfing
LCOE changes with different PPA values, even without debt, taxes, etc was created by Colin Schimmelfing
Hi NREL forum (aka probably Paul!),
For my thesis project, I need to calculate the LCOE for a PV system, and be able to compare these costs across different sized systems.
SAM seems like the right tool for this. However, I am getting different LCOE values if I set different PPA values, regardless of whether there is debt financing or not. I understand that debt costs factor into the LCOE calculation in SAM, and have read the help documentation in SAM as well as anything on the forum having to do with LCOE. To isolate this factor, I set the debt percentage to zero, and I’ve even tried removing all taxes and depreciation income and the LCOE will still change when I change the PPA price.
How can I calculate an LCOE that is not dependent on the PPA price and is instead purely dependent on the non-financing costs of the system?
If it helps, the project is a single owner photovoltaic system, and I am running it on a mac.
19 Jan 2022 11:13 #10522
Replied by Paul Gilman on topic LCOE changes with different PPA values, even without debt, taxes, etc
25 Jan 2022 19:17 #10544
Replied by Colin Schimmelfing on topic LCOE changes with different PPA values, even without debt, taxes, etc
Ah - looks like PVWatts - Single Owner does what I expect, but Photovoltaic - Single Owner does not (see attached). Weird! I should have been more specific as to which type of model I was using in my question.
I'll move my stuff over to PVWatts - Single Owner.
- Colin
- Colin
25 Jan 2022 19:33 #10545
Ah - I see - I was using the 'DSCR' value instead of fixed payments. Setting the debt to use fixed payments gave me consistent LCOE values.
26 Jan 2022 12:38 #10550
Hi Colin,
Yes, using the "DSCR" option for debt sizing means that the size of debt depends on revenue available for debt service. Changing the PPA price changes revenue, which in turn changes the size of debt. The resulting change in the initial investment and debt payments causes changes in the LCOE.
26 Jan 2022 13:30 #10552
Hmm - ok, I think I spoke too quickly last night.
I think it is a difference between PVWatts and PV-SingleOwner, and unfortunately I do need the functionality of PV-SingleOwner.
If you look in the attached file, even with no DSCR there is still a change in the real LCOE with a change in the PPA.
For instance, I chose a PPA of $0.10 / kWh which gave a real LCOE of 4.58 cents / kWh, but when I chose a PPA of $0.05 / kWh I get a real LCOE of 3.44 cents.
Can you check this out to see if I'm missing something basic?
- Colin
- Colin
