Energy Yield calculation - Detailed PV model
- Ana Ibanez
16 Nov 2021 08:32 - 16 Nov 2021 20:56 #10268
by Ana Ibanez
Energy Yield calculation - Detailed PV model was created by Ana Ibanez
I do not fully understand how the Energy Yield (kWh/kW) is calculated.
According to the info in the Help section, it is as follows: Energy Yield (kWh/kW) = Net Annual Energy (AC kWh) ÷ Nameplate Capacity (DC kW)
But in the model I’m working on, I get an Annual Energy (year 1) of 143,080,528 kWh and the DC nameplate capacity of the systems is 62,496 kW. So the Energy Yield should be 2,289 kWh/kW. Instead, in the Summary page it displays 2,368 kWh/kW.
Thanks in advance.
Ana
Thanks in advance.
Ana
Last edit: 16 Nov 2021 20:56 by Paul Gilman.
16 Nov 2021 21:00 #10269
Replied by Paul Gilman on topic Energy Yield calculation - Detailed PV model
Hi Ana,
Be sure to use the Nameplate DC Capacity from the System Design page for that calculation.
If you still get a different result, please attach a copy of your .sam file so I can investigate.
- Ana Ibanez
18 Nov 2021 00:52 #10278
by Ana Ibanez
Replied by Ana Ibanez on topic Energy Yield calculation - Detailed PV model
Yes, the Nameplate DC Capacity in the System Design page is 62,496 kW.
Please, find attached the .sam file.
Thanks a lot.
Ana
Thanks a lot.
Ana
- Luana
29 Nov 2022 03:50 #11738
by Luana
Replied by Luana on topic Energy Yield calculation - Detailed PV model
Hello
I am having the same. What the energy yield considers as calculation?
- Magnus
29 Nov 2022 03:55 - 29 Nov 2022 16:23 #11739
by Magnus
Replied by Magnus on topic Energy Yield calculation - Detailed PV model
I am encountering the exact same problem as mentioned above. The annual AC energy 624'455 MWh
The nameplate DC is 261 MWp
This should give a Specific yield of 2392.5 kWh/kWp, but the summary gives 2557 kWh/kWp, which doesn't make sense to me.
Do you know where this comes from?
Kind regards,
A. Magnus
Kind regards,
A. Magnus
Last edit: 29 Nov 2022 16:23 by Paul Gilman.
29 Nov 2022 16:40 #11742
Hi Magnus,
Could you attach the .sam file that generates those results? In my tests, the "energy yield" metric is correctly calculated.
The description of the metric is in the "Performance Metrics" section of Help:
samrepo.nlr.gov/help/mtp_kwhkwyear1.html
The source code for the calculation is here:
github.com/NREL/ssc/blob/develop/ssc/cmod_pvsamv1.cpp#L3183
