Contour Graphs
- kevinclements
29 Oct 2012 12:18 #981
by kevinclements
Contour Graphs was created by kevinclements
I am having problems getting SAM to generate a contour graph of Annual Energy based on a parametric analysis of Tilt and Azimuth. The Contour lines are not continuous so it seems that SAM is just not graphing the results.
31 Oct 2012 11:14 #982
Replied by Paul Gilman on topic Contour Graphs
Would you mind replying with a copy of your .zsam file attached so I can help troubleshoot?
One possibility is that the range of values in your parametric analysis is not wide enough to generate the graph you expect to see.
- kevinclements
01 Nov 2012 10:52 #983
by kevinclements
Replied by kevinclements on topic Contour Graphs
Hi Paul --
Please find the .zsam file attached. Thanks.
Best,
Kevin
Best,
Kevin
02 Nov 2012 10:04 #984
Hi Kevin,
The graph is correctly showing results for your analysis. You set up a parameteric analysis with a range of tilt angles between 0 and 20 degrees, and azimuth values between 150 and 225 degrees. Here's one interpretation of the countour graph:
In the attached .zsam file, I added a second case with a wider range of tilt and azimuth values so you can more clearly see which values maximize total annual output over the full range of possible values.
Does that address your concern?
- kevinclements
06 Nov 2012 13:24 #985
by kevinclements
I am running on MAC. I think that must be the problem. I tried to run your file and got the attached error message. I also attached an image of what my graph looks like when i set it up in SAM. Thanks for your help with this.
09 Nov 2012 09:03 #986
Hi Kevin,
It turns out that there is a bug in the contour graphing function in the Beta version (SAM 2012.9.27). We are working to resolve that for the Fall 2012 release at the end of November.
Thank you for helping us find the problem.
