SAM Installation Folder
17 Jul 2019 08:59 - 13 Mar 2020 09:57 #7549
SAM Installation Folder was created by Paul Gilman
When you run SAM's installation program in Windows, it installs SAM by default in C:\SAM\[version number]\ For example, it would install SAM 2020.2.29 in C:\SAM\2020.2.29\.
On a Mac, you can find the installation folder in a Finder window as follows: Navigate to the SAM app, control-click the app's icon, click Show Package Contents, and navigate to Contents. Alternatively, assuming SAM is installed in the Applications folder, you can open a terminal window and go to My Mac/Applications/SAM.app.
In Linux, by default SAM installs in either /home/SAM or /opt/SAM, depending on whether you are running Linux as administrator. The installation folder for each version is .../SAM/[version number], for example /home/SAM/2020.2.29.
libraries contains CSV files with parameter data for SAM's equipment libraries for PV modules, inverters, wind turbines, and CSP system components.
runtime contains various files that SAM uses to display information in the user interface including LK scripts for macros and Excel files for the cash flow Send-to-Excel feature.
solar_resource and wind_resource contain sample weather data files for the solar and wind performance models.
The remaining folders (x64, macOS, etc.) contain executable and dynamic library files, including the sdktool executable for the SAM Software Development Kit .
The contents of the SAM installation folder are:Changing files in the SAM installation folders may cause SAM to stop working or change the results of simulations.
Last edit: 13 Mar 2020 09:57 by Paul Gilman.
- Kota Strel
07 Mar 2020 16:15 #8024
by Kota Strel
Replied by Kota Strel on topic SAM Installation Folder
Thanks!
Best Regards,
Best Regards,
