PV Modules and Inverters not in Database
05 Oct 2015 11:51 - 06 Dec 2021 10:10 #3787
PV Modules and Inverters not in Database was created by Paul Gilman
The module and inverter libraries for SAM's Detailed Photovoltaic Model come from data provided by the California Energy Commission (CEC). We create a new library from the CEC data each time we release a new version of SAM. Because the CEC data is updated more frequently than SAM releases, the SAM library is likely to be out of date compared to the CEC database.
If you are an equipment manufacturer and want information about adding inverters and modules to the CEC lists, see this CEC website .
If you are using SAM's detailed photovoltaic model for a photovoltaic system that uses a module or inverter that is not included in SAM's libraries, you can use the CEC Performance Model with User Entered Specifications or Inverter Datasheet options on the Module and Inverter input pages, respectively. Those options allow you to enter data from a manufacturer's data sheet. Behind the scenes, SAM generates the coefficients it needs to model the equipment.
Once you enter the specifications, you can use the Save and Load buttons at the bottom of the input page to save them to a text file to use with other SAM files or to share with your colleagues.
On the Module page, choose CEC Performance Model with User Entered Specifications:
On the Inverter page, choose Inverter Datasheet:
When you use these options, you are relying on data provided by the manufacturer. For equipment that is in SAM's libraries, you may find that the manufacturer data differs from the data in the library. That is because the libraries use data provided to the California Energy Commission that includes performance parameters provided by testing laboratories.
You can also import module and inverter data from PVsyst PAN and OND files. For instructions, see: sam.nlr.gov/forum/forum-general/3386
Last edit: 06 Dec 2021 10:10 by Paul Gilman.
- Yash Agarwala
14 Sep 2020 20:22 #8733
by Yash Agarwala
Replied by Yash Agarwala on topic PV Modules and Inverters not in Database
Is it not possible to incorporate a Hybrid Inverter with its input characteristics related to the battery side of things?
I am currently only able to input data for a standard inverter and not a hybrid inverter.
Kind Regards
Yash.
Kind Regards
Yash.
16 Sep 2020 17:12 #8749
Replied by Paul Gilman on topic PV Modules and Inverters not in Database
Hi Yash,
SAM does not differentiate between different inverter capabilities, so for example, it is possible to model an inverter that only has one input as if it had multiple inputs.
For PV-battery systems with DC-connected batteries, SAM assumes the inverter can operate as a hybrid inverter (one that can be connected to both a PV array and battery) whether or not the physical inverter has those capabilities.
Best regard,
Best regard,
- Ayesha
07 Apr 2021 08:06 #9434
by Ayesha
Replied by Ayesha on topic PV Modules and Inverters not in Database
Hi Paul
When using the Inverter Database and creating a simulation report, SAM crashes. I have tried this with multiple models. The report works for the other inverter options. How do I fix this?
Kind regards
Ayesha
Kind regards
Ayesha
07 Apr 2021 09:17 #9435
- Ayesha
08 Apr 2021 06:47 #9438
by Ayesha
Hi Paul
I have attached the file, it crashes when I try to save the PDF to a location. I think it has to do with the battery system too. The inverter database works individually, and the battery system works individually, however it crashes when used together.
