Sandia Library Modules mounting configuration
- nino
20 Mar 2017 18:38 #5260
by nino
Sandia Library Modules mounting configuration was created by nino
I am using SAM to perform Flat Plate PV analysis with 'Sandia PV Array Performance Model with Module Database'.
Each module from Sandia Library comes with predefined irradiance/wind speed/temperature factors: 'a' and 'b' and 'dT'.
I am wondering: is it possible to identify the mounting configuration of the Sandia module, based on its 'dT' value?
This is basically my question.
I am fully aware that I can somewhat define the mounting configuration of the module by picking it from the 'Module Structure and Mounting' drop list. But I do not want to do this. I would like to use only those 'a', 'b' and 'dT' Sandia Modules Library values which are specifically set for that module. Not manually enter them, nor use those default ones defined by 'Sandia Cell Temperature Model'.
I am also aware of the fact that 'CEC Performance Model with Module Database' does much better job in terms of setting custom mounting configuration. But I do not want to use CEC, I would like to use Sandia Model.
Please let me know, if my question was not clear enough.
Basically, I am trying to predict the mounting configuration of Sandia Library's module, based on its 'dT' value.
s6.postimg.org/n7feft8ld/delta_T.jpg
Can something like this be predicted:
dt is 2 or 3: Open rack
dt is 1: Close roof mount
dt is 0: Insulated back
Thank you for the reply.
20 Mar 2017 20:16 #5261
Replied by Paul Gilman on topic Sandia Library Modules mounting configuration
Yes. The approach you describe makes sense, and is consistent with the description of the dT parameter in the King (2004) description of the Sandia module model.
- nino
21 Mar 2017 04:58 #5262
by nino
Replied by nino on topic Sandia Library Modules mounting configuration
Thank you for the quick reply Paul!
I was wondering if I could ask another, just a bit different question:
In SAM application, I am looking at 'CEC Performance Model with User Entered Specifications'.
In 'SAM Photovoltaic Model Technical Reference.pdf' I've read that it is based on: Dobos A.(2012)
“An Improved Coefficient Calculator for the California Energy Commission 6 Parameter Photo-voltaic Module Model".
Is it possible that some similar coefficients calculator exists for Sandia Performance Model?
If not, then how are values from Sandia Modules Library .csv file generated?
24 Mar 2017 14:04 #5263
The Sandia module model differs from the CEC model in that the Sandia model uses equations with coefficients that must be determined empirically from measurements taken during module testing. Those coefficients cannot be determined mathematically without the test data.
This empirical approach is described in King (2004) "Photovoltaic Array Performance Model."
- nino
24 Mar 2017 17:25 #5264
by nino
Thank you once again for the clear explanation Paul.
Regards, Nino.
Regards, Nino.
- nino
26 Mar 2017 10:53 #5265
by nino
Paul, just one more question please:
I took a look at your 'Libraries' page on sam.nlr.gov website:
sam.nlr.gov/libraries
It contains Sandia Modules Library from 2015/6/30.
Does this mean that the Sandia Modules Library hasn't been updated since 2015?
If not, then are there plans to update this library?
I am currently not able to check this, but could it be that the newest SAM 2017.1.17 software comes with updated Sandia Modules Library?
