Adding a new wind turbine
- reppinger
11 Apr 2012 07:47 #468
by reppinger
Adding a new wind turbine was created by reppinger
Is it possible to add a small wind turbine? Thank you,
11 Apr 2012 14:00 #469
Replied by Paul Gilman on topic Adding a new wind turbine
You can use SAM's library editor to add a small turbine. Please see the instructions on
this post
If you need help adding the turbine, please attach a copy of the turbine's power curve, along with its nameplate capacity and rotor diameter in a reply to this post, and I will create a library file for you.
- reppinger
12 Apr 2012 14:07 #470
by reppinger
Replied by reppinger on topic Adding a new wind turbine
Thanks Paul. The link doesn't seem to work. I read your instructions to add a turbine by going through the large wind section. Is this link the same?
Rick
Rick
12 Apr 2012 16:13 #471
Sorry about that Rick. I fixed the link, so it should work now. And, yes the link points to the instructions for adding a turbine to the large wind turbine library. You can use the same procedure to add a turbine to the small wind turbine library, "SAM/Small Scale Wind Turbine Library." It uses the SmallScaleWindTurbine library type.
- reppinger
13 Apr 2012 08:13 #472
by reppinger
Thanks Paul.
- reppinger
13 Apr 2012 11:12 #473
by reppinger
Paul, I successfully entered the performance curve but have looked everywhere to add the capital cost data for our turbine. Thanks again for your time
Rick
Rick
