Working fluid
- jeremie
27 Mar 2012 15:18 #417
by jeremie
Working fluid was created by jeremie
How can I change the working fluid of the power block. Is there an option, if not what procedure should I take to do it.
I am simulation a ORC cycle with parabolic trough and I want to use the physical model.
Thank you
Thank you
28 Mar 2012 15:18 #418
Replied by Paul Gilman on topic Working fluid
The power cycle models for the SAM CSP technologies (excluding the Empirical Trough) assume a steam Rankine system.
However, because the cycle efficiency is an input, if the relative off-design behavior of the organic cycle is similar to the relative behavior of the steam cycle, you might be able to model the organic cycle by adjusting the design-point cycle efficiency to the desired value.
For more information on how the power cycle is modeled, including relative off-design performance, see M Wagner's "Methodology for Constructing
Reduced-Order Power Block Performance Models for CSP Applications" ( www.nlr.gov/docs/fy11osti/49370.pdf ).
If the off-design behavior described in this paper does not match the organic cycle and the cycle often operates away from the design point, we would recommend using the empirical trough model instead of the physical trough model. You can specify coefficients in the empirical model to approximate the performance of organic Rankine cycles. You could use the coefficients for the APS Ormat 1MWe 300C option in the Power Cycle library as a starting point.
