Field Optical Focus Fraction
- ManPC
10 Feb 2016 06:14 #4056
by ManPC
Field Optical Focus Fraction was created by ManPC
I'm doing my dissertation about a CSP Power Tower plant (100 MWe, 8 hours TES), but to characterize losses produced by defocusing, I need to know what is "Field Optical Focus Fraction". Is the defocused area fraction?
Secondly, I have a question: the field optical efficiency is affected by "field optical focus fraction"?
How can I know the losses produced by defocusing?
Manuel.
Manuel.
10 Feb 2016 10:54 #4057
Replied by Paul Gilman on topic Field Optical Focus Fraction
Dear Manuel,
The "field optical focus fraction" is the fraction of heliostats in the field that are focused. A value of 1 means that 100% of the heliostats are focused. A value of 0.6 means that 60% of the field is focused.
Yes, the "field optical efficiency" includes the effect of defocused heliostats. You can see that clearly in the graph below, which shows the optical efficiency over a period of days when the field defocusses on some afternoons.
SAM does not report defocusing losses as a separate value, but you should be able to analyze the results to calculate an estimate.
- ManPC
11 Feb 2016 04:00 #4058
by ManPC
Replied by ManPC on topic Field Optical Focus Fraction
Thanks for your prompt response.
I have one more question. Is related by thermic balance in the plant. In order of appearance, we have:
DNI*effective_Area_heliostats
- Optical Loss
- Defocusing Loss (calculated by "field optical focus fraction")
- Heliostat Availability Loss
= Receiver Thermal Power Absorbed
- Receiver Thermal Power Losses to convection and radiation
- TES Thermal Losses from tanks
= Cycle thermal power input
However, "DNI*effective_Area_heliostats - (Optical Losses + Defocusing Losses + Heliostat Availability Losses)" is not equal to "Receiver Thermal Power Absorbed"
Receiver Thermal Power Absorbed must be equal to "DNI*effective_Area_heliostats - (Optical Losses + Defocusing Losses + Heliostat Availability Losses)".
Is there another loss that SAM is not reporting?
PS: I have calculated "Defocusing Loss":
(1 - field optical focus fraction)*DNI*effective_Area_heliostats*heliostat availability
Manuel.
- Optical Loss
Manuel.
- ManPC
15 Feb 2016 05:54 #4059
by ManPC
Do you have an explanation?
Thanks.
Manuel.
Thanks.
Manuel.
15 Feb 2016 10:32 #4060
Dear Manuel,
Please see these posts, and let me know if you still have any questions:
sam.nlr.gov/content/calculating-system-efficiency-trough-and-tower-systems
sam.nlr.gov/node/69259
- salraqqad
23 Sep 2016 13:44 #4061
by salraqqad
Replied by salraqqad on topic Field Optical Focus Fraction
I'm having a huge issue with my model. The output Electricity spikes and whenever it does that there is a lowered optical fraction (lower than 1). Does anyone know what reason there could be for this?
